Thread: Incomplete corridor feature lines (rehab)
    2012-04
    2
    Default Incomplete corridor feature lines (rehab)
    Hi! I'm having a real problem with the corridor crown feature line.
    I'm trying to make a minimum level profile for a road rehab and I am using the overlaymillandlevel2 assembly,
    then I wantto take out the corridor crown feature line in the profile view so I can make a geometry over it.
    The problem is that the crown feature line has gaps, uneven gaps, and i can take out only small segments
    in the profileview.
    Any ideas? pls!
    2015-12
    Arizona
    2,478
    Default Re: Incomplete corridor feature lines (rehab)
    sounds like you should try exporting that particular profile to XML
    turing the profile data at the end of the file into a TXT file and then use Create Profile from file option to brin it back in to the file whole and complete
  1. Extract corridor feature lines through XRef
    Last Post: 2013-08-12, 01:42 PM
  2. Polyines from Corridor Feature Lines
    By vkumar.205005 in forum AutoCAD Civil 3D - General
    Last Post: 2009-07-29, 08:27 PM
  3. Create Multiple Feature Lines from Corridor
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-04-24, 07:21 PM
  4. Curved Corridor Feature Lines
    Last Post: 2007-10-01, 09:04 PM
  5. Changing the style of your Corridor Feature Lines
    By melanie.santer in forum Civil 3D Tips & Tricks
    Last Post: 2006-10-27, 03:39 AM
