Thread: Tiled material maps rendering with black lines
    2012-01
    Milwaukee, WI USA
    2
    Default Tiled material maps rendering with black lines
    So I just started having some problems with my tiled materials. Whenever I render something, any material that is a tiled bitmap renders with black lines, and the farther away the camera is the more dark the lines become. I am not sure what I did, or how to fix it. I am using 3ds Max Design 2013 (Infrastructure suite), and mental ray. Any help is appreciated. See attached image for what is happening. Thanks.
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    334
    Default Re: Tiled material maps rendering with black lines
    Couple things to look at:
    1) Set your Bitmap Blur to 0.01 and see if that helps.
    2) What anti-alias/settings are you using?
    Also: are the materials Standard or Arch & Design?
    Glen Loyd
    Parsons Brinckerhoff Project Visualization
    Lead Design Visualization Specialist
    Autodesk Certified Instructor/3ds Max Design 2012 Certified Associate/Professional
    www.pbprojectviz.com
  1. 2014: Rendering does not start, then rendering dialog disappears, then 3D view turns black
    By gabsimonelouise692565 in forum Revit - Rendering
    Last Post: 2015-06-02, 07:34 PM
  2. Material Maps transfer with 3D PDF's
    By slimbek in forum Revit Architecture - General
    Last Post: 2011-08-02, 12:15 AM
  3. Rendering Black Material
    By jodi_sherrell in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-12-29, 04:02 PM
  4. Making Rendering Maps
    By rjcrowther in forum Revit - Rendering
    Last Post: 2006-12-29, 01:41 AM
  5. Seeing textures and material maps in views?
    By sfraney in forum Revit Architecture - General
    Last Post: 2006-12-28, 03:28 PM
Tags for this Thread
