Thread: Canal formation - criteria - as per site condition- how do assembly change - (created sub assembly from polylines)
    2012-05
    salem, india
    3
    Default Canal formation - criteria - as per site condition- how do assembly change - (created sub assembly from polylines)
    im working in canal formation earthwork cut & fill qty calculation, as per the procedures i created corridor, generated sample & cross sections but the one thing is, for 1.5 to 2.00m cutting (as per ground level) the spoil bank & jeep track should come above the ground level. while here the package calculates this portions as cutting.... how do i have to manage to give input for it (also i have attached the file for design procedures..) kindly consider it...
    Question arises :
    1. how can the cross sections for individual assembly height of canal be changed (i.e upto the ground level, since im working with the assembly for canal portion i have created it by actual dimensions & the spoil bank (berm portions) should start from ground level..?)
    2. For clear understanding purpose...
    i) just zoom & watch the cross section diagram (0+120.00, 0+280, 300) the bottom of canal reached the ground level & from that berm portions are created...this is the case originally we should follow.
    ii) as a critical cases watch the cross sections for (140, 160, 180) where the berm portions comes in cutting side, since the berm portions must be in filling....
    2015-12
    Arizona
    2,478
    Default Re: Canal formation - criteria - as per site condition- how do assembly change - (created sub assembly from polylines)
    your assembly from polyline is not go to do what you need
    try generic links
    and at least two(2) conditional cut fill sub assemblies
  1. Replies: 1
    Last Post: 2012-05-28, 04:58 PM
  2. Component Pattern with Holes Created at Assembly Level
    Last Post: 2008-06-06, 07:00 PM
  3. Add created I-Part or I-Assembly to content Center
    By vinay_dabhade.90195 in forum Inventor - General
    Last Post: 2007-05-08, 12:12 AM
  4. Unable to open drawings created from main assembly.
    By paula in forum Inventor - General
    Last Post: 2006-02-27, 04:38 PM
  5. Assembly Plant Filter-Regulator-Lubricator Assembly
    By dcbenson001 in forum AutoCAD Gallery
    Last Post: 2005-06-14, 01:40 PM
