Thread: Canal formation - criteria - as per site condition- how do assembly change - (created sub assembly from polylines)
    2012-05
    salem, india
    3
    Default Canal formation - criteria - as per site condition- how do assembly change - (created sub assembly from polylines)
    im working in canal formation earthwork cut & fill qty calculation, as per the procedures i created corridor, generated sample & cross sections but the one thing is, for 1.5 to 2.00m cutting (as per ground level) the spoil bank & jeep track should come above the ground level. while here the package calculates this portions as cutting.... how do i have to manage to give input for it (also i have attached the file for design procedures..) kindly consider it...
    Question arises :
    1. how can the cross sections for individual assembly height of canal be changed (i.e upto the ground level, since im working with the assembly for canal portion i have created it by actual dimensions & the spoil bank (berm portions) should start from ground level..?)
    2. For clear understanding purpose...
    i) just zoom & watch the cross section diagram (0+120.00, 0+280, 300) the bottom of canal reached the ground level & from that berm portions are created...this is the case originally we should follow.
    ii) as a critical cases watch the cross sections for (140, 160, 180) where the berm portions comes in cutting side, since the berm portions must be in filling....
    2015-12
    Arizona
    2,478
    Default Re: Canal formation - criteria - as per site condition- how do assembly change - (created sub assembly from polylines)
    use generic links, use at least two conditional cut/fill sub assemblies
  1. Replies: 1
    Last Post: 2012-05-28, 04:56 PM
  2. Component Pattern with Holes Created at Assembly Level
    Last Post: 2008-06-06, 07:00 PM
  3. Add created I-Part or I-Assembly to content Center
    By vinay_dabhade.90195 in forum Inventor - General
    Last Post: 2007-05-08, 12:12 AM
  4. Unable to open drawings created from main assembly.
    By paula in forum Inventor - General
    Last Post: 2006-02-27, 04:38 PM
  5. Assembly Plant Filter-Regulator-Lubricator Assembly
    By dcbenson001 in forum AutoCAD Gallery
    Last Post: 2005-06-14, 01:40 PM
