Results 1 to 6 of 6
Thread: Opening Autocad 2012
    2012-06
    Default Opening Autocad 2012
    Each time I start Autocad 2012 it says "first use initialising". If I close Autocad without turning off the computer it starts normally but not if I turn the computer off and back on again.
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Re: Opening Autocad 2012
    Try to set system variable
    Startup=0
    Cairo - no, not Illinois
    4,766
    it sounds like there's something in your windows startup /boot process that is resetting the registry to a previous state, or re-writing your local user profile information. Or possibly on shutdown something is running that edits the registry or user account info.
    Are you on a domain? is your IT group doing something with the login scripts? are Group Policies being used by IT?
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,015
    Isn't that normal?
    I see the same behavior with 2012. I also noticed it takes longer to open the first time after a computer restart.
    Jeff Paulsen
    Active Member wolfgrrlone's Avatar
    2003-05
    54
    This is a local user vs. admin user issue. I have pestered my IT guys about it, but since we have local user rights and not admin rights, we are stuck with the "frist run" dialog each time we reboot.
    ACAD Mech 2012, Win 7 64 bit
    2004-08
    Hartford, Michigan
    3,194
    My splash screen always displays this on first run after a reboot. It is default behavior programed that way. Its just telling you that it is the first run of the day.
  1. Replies: 0
    Last Post: 2013-06-12, 04:34 PM
  2. 2012: AutoCAD 2012 / 2013 Opening Slowly
    By rgreen.184947 in forum AutoCAD General
    Last Post: 2012-10-26, 12:50 PM
  3. 2012: Problems in autocad 2012 when opening files from autocad 2011 saved as 2000
    By debora.fernandes in forum AutoCAD General
    Last Post: 2012-06-30, 02:12 PM
  4. 2012: Error when opening RAC 2012
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2011-08-25, 03:14 PM
  5. AUTOCAD LT 2012 CRASHING WHISLT SAVING/OPENING DWG'S AND PLOTTING PDF'S
    By GARION864363 in forum AutoCAD LT - General
    Last Post: 2011-04-26, 01:18 PM
