Thread: Changing a Ceiling hosted Family to a Level based Family
    Active Member Ms. Serene's Avatar
    2016-02
    Tucson Arizona
    89
    Default Changing a Ceiling hosted Family to a Level based Family
    Is there a way to change a Ceiling Hosed Family to a Level Based Family in Revit 2012? if so can someone send me the steps?
    2007-07
    London, UK
    361
    Default Re: Changing a Ceiling hosted Family to a Level based Family
    No way.
    Starting family templates cannot be changed.
    If you want that kind of flexibility, you need to create the geometry in a empty template and later host it in a face/ceiling/levels/etc template.
    Not the best option for model performance, but great if you want to recycle your libraries.
    2010-08
    5
    The only work-around I've found for this is to do the following:
    -Create a "dummy" project.
    -Create a ceiling and insert the ceiling-based families you'd like to change
    -Open a second project, link in the "dummy" project, and copy-monitor the families.
    -Now you can select these copied families and save them as level based.
    Full disclosure - I've never tried this with ceiling-based families, only with wall-based, but I think it should work.
    2016-02
    Tucson Arizona
    89
    unfortunately I have to figure something out. the Architects don't want to give me a ceiling on this project.
    2015-11
    Madison, WI
    1,318
    We have used a 'Ghost Ceiling' in the past. Basically it has no pattern & minimal thickness. It's really only there to host elements to.
    Best of luck,
    Jeff S.
  1. 2012: Nesting ceiling based families inside a ceiling based family
    By humphrey.ben780631 in forum Revit Architecture - Families
    Last Post: 2012-01-04, 06:16 PM
  2. Revit Face Based Ceiling Components in Ceiling hosted incorrectly
    By jkhmiller in forum Revit MEP - General
    Last Post: 2009-11-03, 03:50 PM
  3. How do you changing a wall based family into a face based one
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2009-07-13, 05:21 AM
  4. Provide a Line-Based Wall Hosted family type. (Ceiling, floor, etc. as well)
    Last Post: 2008-07-04, 11:36 AM
  5. Floor-hosted line-based family?
    By patricks in forum Revit Architecture - Families
    Last Post: 2007-11-29, 08:04 PM
