Results 1 to 1 of 1
Thread: Multiple stretch distances need minimum/maximum dimensions
    2001-04
    West Michigan
    15
    Default Multiple stretch distances need minimum/maximum dimensions
    Hi all, I'm trying to find a way to build some rules into a dynamic block so that the machine it represents can be ordered correctly.
    The attached block is for a conveyor where the overall length can be ordered from 120" down to 70", and the edges of the rectangular tubs within can not be placed closer than 5.5" from either end (in any configuration). Additionally, the two tubs have to keep a minimum separation of 3".
    I've been trying to come up with a way to place a linear parameter or constraint between the tubs to limit the minimum distance to 3", but so far I can't find a way to do this. Does anyone have an idea or understand those pesky constraints better than I do?
    Any help greatly appreciated.
    Ron
  1. Replies: 1
    Last Post: 2015-10-12, 03:51 PM
  2. CM333-1: Maximum Training: Minimum Effort
    By Autodesk University in forum CAD Management and IT
    Last Post: 2015-08-07, 04:06 PM
  3. CP41-1L: Rapid Customizing: Minimum Pain, Maximum Gain
    Last Post: 2013-04-10, 02:30 AM
  4. Replies: 2
    Last Post: 2012-08-04, 05:57 AM
  5. Maximum & Minimum constraints
    By Shaun v Rooyen in forum Revit Architecture - Families
    Last Post: 2005-09-22, 09:05 AM
