Summary: Change a viewport's "Linked to Sheet View" property from "No" to "Yes" in the viewport Properties window if the Layout is in a Sheet Set.
Description: Having to first make a Sheet Set Model View, often from a perfectly good existing viewport except the property "Linked to Sheet View"="No", and then having to select "Place on Sheet" from the Sheet Set Manager only to place a duplicate copy of the original view but with "Linked to Sheet View"="Yes", and then delete the original viewport and hope that the viewport layer settings remained the same, is far more tedious that just switching the original viewport "Linked to Sheet View" property from "No" to "Yes".
This would make using already fully developed sheet layouts that had not previously belonged to a sheet set much easier to add to a sheet set and add sheet set callout blocks for.
Product and Feature: AutoCAD - Sheet Set Manager
Submitted By: Henry Francis on Tue, 12 Jun 2012
