Results 1 to 8 of 8
Thread: MLEADER INSERTION POINT (?)
    Member clxramos583784's Avatar
    2012-06
    27
    Default MLEADER INSERTION POINT (?)
    Hi!
    How can I get mleader insertion point by vba or vb6 code ?
    Thanks !
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: MLEADER INSERTION POINT (?)
    Try this code, not tested thoroughly
    Public Sub ArrowPoint()
        Dim oMText As AcadMText
        Dim oLeader As AcadLeader
        Dim oMLeader As AcadMLeader
        Dim oCircle As AcadCircle
        Dim fpick As Variant
        Dim oEnt As AcadEntity
        Dim lCoords As Variant
        Dim pt1(0 To 2) As Double
        Dim pt2(0 To 2) As Double
        Dim mp(0 To 2) As Double
        Dim align As Integer
        Dim pStr As String
        ThisDrawing.Utility.GetEntity oEnt, fpick, vbCr & "Select leader: "
        If TypeOf oEnt Is AcadLeader Then
        Set oLeader = oEnt
        lCoords = oLeader.Coordinates
        pt1(0) = CDbl(lCoords(0)): pt1(1) = CDbl(lCoords(1)): pt1(2) = CDbl(lCoords(2))
       Set oCircle = ThisDrawing.ModelSpace.AddCircle(pt1, 20)
       ElseIf TypeOf oEnt Is AcadMLeader Then
        Set oMLeader = oEnt
            lCoords = oMLeader.GetLeaderLineVertices(0)
       Else
       MsgBox "Invalid object type selected"
       Exit Sub
       End If
    End Sub
    ~'J'~
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    2012-06
    27
    Thanks FIXO !!!
    2005-05
    Pietari, Venäjä
    1,269
    You're welcome
    Cheers
    Bertrand Russell
    2012-06
    27
    Fixo, take off a doubt, please.
    does this sintaxe code "oMLeader.GetLeaderLineVertices(0)", function only versions 2010 and over or not ?
    Thanks again!
    ps. That code you sent me worked wonderfull.
    2005-05
    Pietari, Venäjä
    1,269
    I tested the code in A2009 all is working in there,
    I know nothing about A2010 and over, sorry
    ~'J'~
    Bertrand Russell
    2012-06
    27
    I tested it Autocad 2010 and worked very well.
    I would like to know about versions 2000 to the 2008.
    Help me more one time in this case: text insertion.
    How do I do to get it ?
    Thanks !!!
    2005-05
    Pietari, Venäjä
    1,269
    Try this quick and dirty code, almost not tested
    Public Sub GetTextBounds()
       Dim oPoly As AcadLWPolyline
        Set oLeader = oEnt
        Dim minp As Variant
        Dim maxp As Variant
        oLeader.Annotation.GetBoundingBox minp, maxp
        Dim pts(7) As Double
        pts(0) = minp(0): pts(1) = minp(1)
        pts(2) = minp(0) + (maxp(0) - minp(0)): pts(3) = minp(1)
        pts(4) = maxp(0): pts(5) = maxp(1)
        pts(6) = minp(0): pts(7) = maxp(1)
      Set oPoly = ThisDrawing.ModelSpace.AddLightWeightPolyline(pts)
      oPoly.Closed = True
      oPoly.color = acRed
        End If
    End Sub
    ~'J'~
    Bertrand Russell
  1. Replies: 21
    Last Post: 2012-10-10, 02:38 PM
  2. RL insertion point
    By kristreagus in forum Dynamic Blocks - Technical
    Last Post: 2007-11-08, 03:33 AM
  3. Placing insertion point at mid-point of flange on a steel section
    By Spenner in forum Dynamic Blocks - Technical
    Last Post: 2007-06-18, 01:53 PM
  4. Insertion Point
    By kwong in forum Revit Architecture - Families
    Last Post: 2005-03-19, 07:27 AM
  5. Insertion Point
    By kwong in forum Revit Architecture - General
