Results 1 to 10 of 15
Thread: define a project data area in map 3d
    2012-03
    9
    Default define a project data area in map 3d
    Hi all. Is it possible to reduce the amount of GIS data that im seeing from our state wide sde?As I only need to see the sde data from a project specific area, say 2km x 2km. Not the entire state. Thanks Using MAP 3d 2011
    2012-05
    93
    Default Re: define a project data area in map 3d
    Try to hide the unwanted areas by means of _WIPEOUT command...
    TN/KY Area
    1,640
    When you add the connection to the SDE you can query on location by locate on map. After you added the SDE connection you can go back and query based on location.
    TN/KY Area
    1,640
    Quote Originally Posted by sieradz928384 View Post
    NOT the proper way and would require a wipe out with a hole in the center.
    2012-05
    93
    Quote Originally Posted by Jmurphy View Post
    Definetely it IS a proper way, sir.
    I meant four rectangular wipeouts around the scene, like this: before and after.
    P.S. for the Admin
    Why can't I change my nickname..?
    Ain't a number as sieradz928384, I'm a proud italian old cad-man, with a first and even a lastname!
    Thanx in advance, have all a good afternoon!
    2001-12
    St. Louis
    5,407
    P.S. for the Admin
    There is a link at the top of this page "FAQ", under that, you will find the answer...
    Cheers!
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2012-05
    93
    Quote Originally Posted by Wanderer View Post
    Thank you Lady, everything is all right now!
    2012-03
    9
    Ok so it is one way but that would require me to have a wipe out the size of the state of South Australia with a 2 x 2 km hole around the project area. P.S. South Australia is 1200km x 1300km
    2012-05
    93
    Martin,
    you only have to draw 4 wipeouts around the project area: it's an one-minute stuff, trust me.
    Cairo - no, not Illinois
    5,069
    Novarese - the problem with doing a wipeout is that one would still be sucking all the data in, and then hiding the overwhelming majority of it. Using a query will bring in only the data that's needed. in the situation described, using wipouts to hide the unwanted data means bringing in 360,000 times as much area as desired. that woould make a pretty big difference in performance.....
  1. 2015: Data Shortcut Project Referencing Wrong Project Filies
    By g.wollf697165 in forum AutoCAD Civil 3D - General
    Last Post: 2016-08-03, 07:26 PM
  2. Data Extraction - help with area
    By bmckenzie in forum AutoCAD Customization
    Last Post: 2008-09-16, 07:08 PM
  3. Define a print area by picking two points
    Last Post: 2007-09-27, 08:00 AM
  4. Replies: 12
    Last Post: 2007-06-01, 05:22 AM
  5. Mixing Area Data and a Title Block
    By The Sweg in forum Revit Architecture - General
    Last Post: 2005-10-13, 02:10 PM
