Hi,
I was wondering if there was a 3rd party utility for Autocad that would give you the same functionality as the "S" key does in Solidworks.
Hi,
So what does the "S" key do in SW?
When you hit the S key, a box appears at the end of your cursor (no matter where the cursor is) that contains frequently used commands. It is completely customizable as to what commands are inside it. I find it better and faster than using aliases which sometimes requires you to take your right hand off the mouse to enter the alias.
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
There's also the command auto-complete which has an option to work from frequently used commands. It can be a little slow though.
