Results 1 to 7 of 7
Thread: Camera in Glass reflection why?
    2010-08
    2
    Default Camera in Glass reflection why?
    I created a glass material using the Raytrace shader. I made this glass to be fully reflective like a tinted storefront window. My problem is that for some reason the camera is reflecting off of this glass and I can't figure out how to turn out the camera so when I render my scene the camera will not reflect in the glass. The camera lens renders as a black ball looking thing. Can somebody let me know how to eliminate the camera from rendering in the reflected glass? See attached for a rendering preview showing my problem.
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Default Re: Camera in Glass reflection why?
    Select the camera, right-click, select Object Properties, uncheck the "renderable" option.
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Detailer, Proctor Productions
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2010-08
    2
    Thank you for the feedback, but that did not work. I am still trying to figure it out.
    2004-10
    Denver, Colorado
    1,515
    Now that I think about it, I think there's a similar setting in mr. You'd need to adjust this setting since youre using mr. I don't have it in front of me right now, so I can't point you right to it...
    Phillip Bradshaw
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    How can you tell it's the camera when it looks like a ball? Unless the mesh of the camera gizmo can be changed (which I don't know how or can it be done.) Could it be a hidden object and you accidentally ticked Render Occluded objects?
    As far as I know, cameras do not render regardless of the "Renderable" object setting.
    Did you solve this already? We'd also want to know what had caused it.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2004-10
    Denver, Colorado
    1,515
    Quote Originally Posted by arshiel88 View Post
    Ya know, I was wondering about that too. I'm pretty sure it's NOT a camera, but another object altogether.
    Phillip Bradshaw
    I could stop if I wanted to rbcameron1's Avatar
    2008-09
    Nebraska & Iowa
    378
    I'm pretty sure cameras don't show up in renderings...
    Try rotating the background sky 90 degrees. It might be the finite point where the map wraps to and might be causing an anomaly in the scene.
    RB Cameron, AIA, LEED AP, EDAC
    BIM Coordinator - VDC Coordinator - Visualization Artist
    Download Healthcare Revit+3dsMax Models
    Download Revit+3dsMax Models
  1. 2013 Shaded camera view glass bug
    By Tobie in forum Revit Architecture - General
    Last Post: 2012-05-01, 04:53 PM
  2. Reflection Mottling?
    By cek in forum Revit - Rendering
    Last Post: 2011-03-22, 02:08 PM
  3. Reflection in mirror
    By nextvkin in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-08-25, 10:15 AM
  4. howto create a glass wall with a glass door
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-01-22, 07:49 PM
  5. reflection image
    By ford347 in forum Revit - Rendering
    Last Post: 2006-09-01, 09:19 PM
