You can change two properties height and space factor:
Public Sub ChangeLineSpaceFactor()
Dim pickPt
Dim oEnt As AcadEntity
Dim oLeader As AcadMLeader
Dim txtHgt As Double
Dim dblLts As Double
Dim setObj As AcadSelectionSet
Dim setColl As AcadSelectionSets
Dim setName As String
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
Dim dxfcode, dxfdata
gpCode(0) = 0
dataValue(0) = "MULTILEADER"
dxfcode = gpCode: dxfdata = dataValue
setName = "$MleaderSelect$"
On Error GoTo Err_Control
With ThisDrawing
Set setColl = .SelectionSets
For Each setObj In setColl
If setObj.Name = setName Then
.SelectionSets.Item(setName).Delete
Exit For
End If
Next
Set setObj = .SelectionSets.Add(setName)
End With
setObj.SelectOnScreen dxfcode, dxfdata
setObj.Highlight True
MsgBox "Selected: " & CStr(setObj.Count & " mleaders")
If setObj.Count > 0 Then
' >> do your changes here :
For Each oEnt In setObj
Set oLeader = oEnt
Set oLeader = oEnt
txtHgt = oLeader.TextHeight
dblLts = oLeader.LinetypeScale
oLeader.TextHeight = txtHgt * 6
oLeader.LinetypeScale = dblLts * 6
Next
End If
Err_Control:
If Err.Number <> 0 Then
MsgBox Err.Description
End If
End Sub
~'J'~
