Thread: Fascia Profile (was>Quick Question.)
    2004-08
    5
    Default Fascia Profile (was>Quick Question.)
    I’ve been working with Revit for about the last 2 to 3 months. I went to a meeting at the Irvine office about 2 months ago and they mentioned something about using different things from other peoples drawings or d/ling them from the augi website. For example I wanted to put a different fascia on my roof and I really don’t have any different examples in my Revit program I have tried to use the Website library but have found nothing for that. If anyone could help It would be appreciated
    2003-05
    5,153
    Default Re: Fascia Profile (was>Quick Question.)
    Hi Jake,
    If you used the "Host Sweep" -Roof Fascia tool to place the fascias around the roof, you can load other profiles from the standard library - Profiles > Roofs, then select the fascia , go to Properties and swap the default profile for the new one(s).
    You can create new profiles, or get others from the AUGI Revit Exchange and / or other sites.
    2004-08
    5
    Quote Originally Posted by beegee
    Hi Jake,
    I dont think it will let me load any of the fascias because I am using the 30 day trial ver. When I go to profile it just says default and nothing else. I've also gone to The web library and found nothing for roof fascia. If you know of any sites that I can d/l anything to help me I am trying convince my boss that this program is the way to go before he puts out the money to buy it.
    thank you.
    2003-05
    5,153
    To load a fascia profile ( there are only a couple in the standard library )
    File > Load from Library > Load Family > Metric ( in my case ) Library > Profiles > Roofs > select profiles.
    Once loaded in the project,
    Select the fascia from a roof plan > Properties > Edit / new > Profile drop down menu > select replace.
    The trial version will allow you to do this.
    The Links page has links to the Augi Revit Exchange and to RevitCity, and ( before Arias chimes in ) there is also symbolmachine.com . These sites will have other profiles. You can also search for facia profiles in the Revit forums using the search keyword " fascia ". You can also make you own profiles, they are not difficult to do.
    HTH.
    Quote Originally Posted by jakedanceparty
    thank you.
  1. Can I build a void into a fascia profile?
    By patagoniadave in forum Revit Architecture - General
    Last Post: 2006-09-12, 08:59 PM
  2. Detail Component not visible in profile used in fascia
    By Haden in forum Revit Architecture - Families
    Last Post: 2005-10-31, 06:07 AM
  3. Fascia Profile
    By markpnet in forum Revit Architecture - General
    Last Post: 2004-08-18, 04:11 PM
  4. subject: fascia details sweeps profile
    By mailtomac1860 in forum Revit Architecture - General
    Last Post: 2004-01-02, 07:37 PM
  5. Possible to cut off a portion of the fascia board profile?
    By Jason in forum Revit Architecture - General
    Last Post: 2003-08-20, 12:14 AM
