Thread: .gdb access to imagery
    2015-10
    24
    Default .gdb access to imagery
    Trying to connect to a geo database containing aerial imagery - do I neeed any patches or files to make this work?
    I have CD3 with map and I am presently resolving the FDO connection issue with the security people in my office, so I decided to point to a .gdb directory where the images are kept locally for ArcGIS users. Can CD3 with Map read a geo database?
    Default Re: .gdb access to imagery
    I'm also facing the same issue.
    6,420
    Can you describe your problem in a little more detail? What version is your db? What version of Map do you have?
    LinkedIn
  1. Viewing .sid imagery in Civil3D
    By unkleroy in forum AutoCAD Civil 3D - General
    Last Post: 2013-12-06, 09:29 PM
  2. 2012 Imagery plots over drawing, even when sent to back
    By cowboys1960fan383217 in forum AutoCAD Map 3D - General
    Last Post: 2013-08-27, 10:37 AM
  3. imagery in task pane doesn't display in map
    By musty175054 in forum AutoCAD Map 3D - General
    Last Post: 2008-12-30, 07:36 AM
  4. Revit 09_mental ray imagery.
    By trombe in forum Revit - Rendering
    Last Post: 2008-04-02, 01:33 PM
