Thread: Shared Coordinates, Survey Points and Graphical Column Schedule
    2002-09
    Madison, WI
    5,686
    Default Shared Coordinates, Survey Points and Graphical Column Schedule
    So we have a project where our Archie decided using 100' base elevation didn't make sense. So he used shared coords and the survey points to change the elevations.
    So I know I can change an elevation tag to read the Project Base Point or the Survey Point. What I can't seem to find is where I can select that for the Graphical Column Schedule? How Do I change the elevations that are shown on a GCS so they read the Survey point/shared coord point.
    Thanks in advance.
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Somerville, MA
    291
    Default Re: Shared Coordinates, Survey Points and Graphical Column Schedule
    Hi David,
    Took me a while to remember what happened on this. We had attempted at one point to add a paratmer to the GCS which would allow you to show either project or shared and when I went to look for it I had to go track down why it wasn't there. The solution which was implemented was that if your levels' type property is set to "Survey Point" then the GCS will show shared coords for the level elevations.
    Ken Marsh
    Owner, Marsh API
    2002-09
    Madison, WI
    5,686
    Thanks Ken,
    I guess the issue really came up after the schedule was already created. It appears that if you have a GCS set-up in a template file, you start your project, someone decides that "Hey lets use xxx'xx" for our elevation", you have to re-create the schedule.
    That was our work around. It didn't seem to do anything if you've already had it created. Or at least that was my experience.
  1. Project Coordinates, Shared Coordinates, and the new Survey Point
    By Wes Macaulay in forum Revit - Platform
    Last Post: 2012-07-05, 06:20 PM
  2. 2010 Shared Coordinates - Base + Survey Points
    By Liz437 in forum Revit Architecture - General
    Last Post: 2009-10-16, 06:12 PM
  3. Graphical column schedule - issue with column location mark
    By brent.vanlelyveld in forum Revit Structure - General
    Last Post: 2009-05-21, 07:58 PM
  4. Graphical Column Schedule and slab/column intersection not show correct in GCS
    By jonas.152865 in forum Revit Structure - General
    Last Post: 2008-07-16, 06:58 AM
  5. Allow shared coordinates for the graphical column schedule
    By jofford in forum Revit Structure - Wish List
    Last Post: 2007-07-03, 11:14 PM
