Thread: Dynamic Block Annotative Scaling
    2012-03
    111
    Default Dynamic Block Annotative Scaling
    Does anyone know if you can edit an existing dynamic block so that the text or attribute can be scaled? Do I have to create a new dynamic block & choose Annotative scaling or can I edit my existing dynamic blocks?
    2009-01
    B5
    544
    Default Re: Dynamic Block Annotative Scaling
    Generally you make the DynBlk Annotative; not the parts in it.
    I think that if you make the Text Annotative and then the DynBlk Annotative they do not interact well.
    2005-02
    Ottawa, KS
    45
    The attribute will do some things you don't want them to do. Just say no. Try using the ANNOTATIVEDWG command in the original block drawing if you have it. Make sure that any text or attributes are NOT annotative before you do it though.
    100 Club heinsite's Avatar
    2005-11
    Kona, Hawaii
    138
    Quote Originally Posted by sovby254640 View Post
    I just did this recently and everything worked fine. The basic block was not annotative, but the attribute text within it was. This is useful when you don't want the basic block objects to change size when annotative scale changes, but you do want the text within the block to change... that is, to remain a defined text height on paper when annotative scales change. The key is to not check the annotative box in the block creation dialog, but check it when you create attributes.
    Dave.
  1. Strange annotative block scaling issue
    By robgraham31 in forum ACA General
    Last Post: 2009-07-16, 06:05 PM
  2. Attribute in Block - Annotative Scaling
    By agoodmansen in forum ACA General
    Last Post: 2008-10-28, 09:38 PM
  3. Annotative Block Scaling Problem.
    By Eddy B in forum AMEP General
    Last Post: 2008-04-30, 08:56 PM
  4. Replies: 0
    Last Post: 2008-03-12, 04:26 AM
  5. Dynamic Block scaling with Annotative text
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2007-06-15, 01:29 PM
