Thread: Removing the double list pairs
    2006-05
    Pind
    80
    Default Removing the double list pairs
    Exactly this is how i need List 1 = ((0 0) (1 0.1) (2 0.1) (3 0.1) (4 0.2) (5 0.2) (6 0.3) (7 0.3))
    First of all the list given above can vary every time secondly i want to seprate the list for same cdr elements and store them to a variable Like i want like this and all the List with similar cdr element and make a list which contain all these values.
    thanks
    List A = (0 0)
    List B = (1 0.1) (2 0.1)(3 0.1)
    List C = ............................etc
    Thanks
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: Removing the double list pairs
    How would you like your variables named? Also are you fine with having them as global variables (i.e. possibly overwriting something else)?
    If so, you could use some code like this:
    (setq List1 '((0 0) (1 0.1) (2 0.1) (3 0.1) (4 0.2) (5 0.2) (6 0.3) (7 0.3))
          n 0)
    (foreach item List1
      (setq var (chr (+ (rem n 26) 65))
            m (/ n 26)
            n (1+ n))
      (while (> m 0)
        (setq var (strcat (chr (+ 65 (rem m 26))) var)
              m (/ m 26)))
      (set (read (strcat "List" var)) item))
    Just note, that I'd advise against doing this. Global variables should be kept to an absolute minimum as they can very easily cause other things to suddenly crash at unexpected times.
  1. Double sheets in list
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2016-03-31, 11:40 PM
  2. removing items from list
    By mixted570595 in forum AutoLISP
    Last Post: 2012-05-06, 01:47 PM
  3. Linked Drawing List Schedule showing double sheets
    By troy.crandell635379 in forum Revit Architecture - General
    Last Post: 2010-04-09, 08:16 AM
  4. Removing Double lines
    By rhayes.99001 in forum ACA General
    Last Post: 2006-06-20, 03:35 PM
  5. Removing duplicate strings in a list
    By whdjr in forum AutoLISP
    Last Post: 2004-06-09, 05:40 PM
