Thread: Sort model tab files alphabetically
    Wish List Administration
    2011-08
    4,581
    Default Sort model tab files alphabetically
    Summary: Under the Model Tab in the sheet set manager have the files sorted alphabetically
    Description: Currently when I am trying to open a file through the model tab it is difficult to find the file I want because the files are not sorted in a random way. I would like the files to be sorted alphabetically similar to working in windows explorer.
    Product and Feature: AutoCAD - Sheet Set Manager
    Submitted By: Jared Murphy on 07/18/2012
    2009-11
    5,719
    Default Re: Sort model tab files alphabetically
    FWIW -
    I also use Sheet Set Manager to access my Civil 3D project models (i.e., Aerial, Alignment, Pipe Network, Surface models, etc.), however, rather than using the Model Views Tab, I simply add an aptly named 'Models' subset to my Sheet Set, with 'Publish Sheets in Subset' set to 'Do Not Publish Sheets'.
    Then, as Sheet Set Manager will open these drawings to the Layout, I add a simple snippet of code to AcadDoc.lsp that checks for "*\\Model*" in the file path, and automagically sets the Model tab current:
    ;;; Activate model tab when opening models from ssm
    (if (and (wcmatch (strcase (getvar 'dwgprefix)) "*\\MODEL*")
             (/= 1 (getvar 'tilemode))
      (setvar 'tilemode 1)
    HTH
    Computer Specs:
  1. Replies: 3
    Last Post: 2017-02-02, 02:04 PM
  2. To be able to sort Data Shortcuts alphabetically.
    Last Post: 2011-11-16, 04:05 AM
  3. Replies: 4
    Last Post: 2011-10-08, 01:11 PM
  4. Replies: 2
    Last Post: 2007-06-12, 11:23 AM
  5. Sort Text alphabetically
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-03-30, 12:13 PM
