Results 1 to 10 of 12
Thread: Changing Coordinate Systems
    2005-02
    Michigan
    23
    Default Changing Coordinate Systems
    Does anyone know how to change a drawing from Michigan GeoRef to State Plane coordinate system? Is there an add on or coordinate calculator somewhere?
    Cairo - no, not Illinois
    4,765
    Default Re: Changing Coordinate Systems
    I'll presume you're talking about Map3d? since vanilla ACAD has no concept of mapping coordinate systems.
    If that's the case, set up a new empty drawing on the coordinate grid you want to be on, and then query in the objects from the source drawing.
    2005-02
    Michigan
    23
    I am using plain ACAD, not Map3d.
    4,765
    Then, you _have_ no coordinate system to worry about. just a cartesian gridn of x, y (& z).
    Can you clarify what you mean by "Michigan GeoRef"? That does not come up in the list of defined coordinate systems (Map3d 2011) - there is a "Nad83 datum, Georef Hotine Oblique for whole state (meter)" listed -
    And, which Michigan state plane system you want to be on? There are about 25 listed for that state....
    2005-02
    Michigan
    23
    I downloaded a file from http://www.mcgi.state.mi.us/mgdl/?rel=ext&action=sext, and it appears it is done in the Michigan GeoRef coordinate system. I need to convert that to a different coordinate system a client uses, NAD-83 Datum, Michigan State Plane, North Zone, US Feet.
    4,765
    Ok, going though the readme there for MapInfo suggests that it's the Hotine Oblique (Meters) being used. Can you confirm that the distances in the file you downloaded are in meters rather than feet?
    If so, draw a box, using points in the drawing you can readily identiy, wblock that out, and post the drawing file here. I can convert that for you, and you should be able to insert it as a block at 0,0,0 & use it to scale and relocate the GeoRef file to match.
    2005-02
    Michigan
    23
    It was in meters when I downloaded. I scaled it to feet, at 0,0. Attached is the block.
    Thank you for all your help.
    4,765
    Please create the box without scaling, doing that makes it unfeasible to query the linework into the desired coordinate system, because the scaled version is no longer on any identifiable system.
    4,765
    Also, if you're using 2013, please save the box back to 2010 format -- corp has not upgraded.
    2005-02
    Michigan
    23
    I didn't realize that would screw it up, sorry. Also, just out of curiosity, which program do you use?
    Again, thanks for the help.
  1. How to set zero coordinate systems
    By dmurphy508490 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-06-01, 06:29 PM
  2. Change coordinate systems on the fly
    By jessebelcher in forum AutoCAD Map 3D - Wish List
    Last Post: 2010-02-09, 09:13 PM
  3. Multiple coordinate systems
    By benmay in forum Revit Structure - General
    Last Post: 2010-02-01, 08:56 PM
  4. Set up two coordinate systems in same drawing
    By A Myth in forum AutoCAD General
    Last Post: 2007-02-17, 09:59 PM
  5. DWG and Image have different Coordinate Systems, what to do?
    By dpelletier in forum AutoCAD Map 3D - General
    Last Post: 2005-08-02, 04:04 PM
