Thread: attribute text doesnt want to move
    2012-04
    Redlands CA.
    18
    Default attribute text doesnt want to move
    I am creating a dynamic block for spot elevation points. I want the attributes to stretch/move when stretching the line out, then be able to rotate 180d then flip on the vert. line. There must be something im doing wrong. No matter what i do, the attributes dont want to move rotater or do anything. I created a points for them and linked the rotate, linear, flip to the point and the points to the attributes but nothing. If someone could help, and maybe even go step by step on how you did that
    Thanks for anyhelp
    2010-06
    57
    Default Re: attribute text doesnt want to move
    I'm sure there are wiser folk out there that will be able to give you more help but when you created the attibute did you make sure that the "lock position" wasn't checked? I have found sometimes it seems to default to this.
    All AUGI, all the time Norton_cad's Avatar
    2016-02
    Sydney, Australia
    512
    I agree with Lesleys point. Also consider the ATTEDIT command. Lastly have a look at this thread:-
    http://forums.augi.com/showthread.ph...by-other-means
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2012-04
    Redlands CA.
    18
    I did make sure that it was lock while i was creating the attributes, i even tried linking it to the point and just moving the point per a tutorial i found on here.
    that link was for a block for coodinates. The one i have is to manually add spot elevation point. Im using ACA2013 and dont have civil. We do lite grading for like ada ramps
    Thanks for the info
  1. Attribute text enhancement - linked attribute text
    Last Post: 2014-10-22, 06:33 PM
  2. How do I move "locked" attribute text in 2011?
    By thinkdesign_liesl in forum AutoCAD General
    Last Post: 2010-11-22, 12:50 PM
  3. AutoCAD 2006 - Unable to move Attribute Text via Grips
    By andrew.90224 in forum AutoCAD General
    Last Post: 2007-04-02, 01:00 PM
  4. Replies: 5
    Last Post: 2006-08-11, 01:32 PM
  5. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
