Thread: Field return Z value WITH conversion factor
    2011-10
    29
    Default Field return Z value WITH conversion factor
    I am trying to create a block showing the Z elevation of particular points.
    It could be used on surveys, drawn in metres, or structures, drawn in millimetres.
    In both cases the value returned needs to be in metres.
    For objects drawn in metres its fine, I can just use the 'Position' variable and de-select X and Y.
    I had hoped to use the same variable (in another attribute, controlling the two with visibility) for objects drawn in millimetres, but with a conversion factor to scale the value to metres.
    The 'Position 1' object will allow applying a conversion, but there is only position options for X and Y
    Does anyone know of any clever tricks?
    100 Club StDoodle's Avatar
    2015-10
    158
    Default Re: Field return Z value WITH conversion factor
    First, set the field to use a Formula. Do your conversion math, and then insert another field (yes, it's field-ception, fields inside of fields). That nested field can be the same as your original (no-conversion version) field (also allowing formatting). Hope this helps.
    2012-02-24: Finally got around to installing my home copy of AutoCAD... no longer relying on my horrible memory for "how-to" advice!
    2011-10
    29
    *Punches the air*
    You Hero! Many thanks
    2006-04
    I echo Kernal_CAD_Monkey's praise...many, many thanks. I was sure it was possible, but couldn't get my head around the field-within-field concept until now.
  1. Replies: 10
    Last Post: 2016-06-27, 12:04 AM
  2. .NET Return Conversion to TypedValue
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2015-10-14, 05:10 PM
  3. Carriage Return in SSM Field
    Last Post: 2010-03-15, 01:40 PM
  4. Alternate Units Conversion Factor Error!
    By aledtaylor79401 in forum AutoCAD General
    Last Post: 2007-12-07, 07:20 PM
  5. How do you create a Boxed Return or Cornice Return?
    By rgecy in forum Revit Architecture - General
    Last Post: 2004-05-20, 04:42 PM
