Thread: Styling Based on Attribute Values
    2012-07
    3
    Question Styling Based on Attribute Values
    I am using Map 3D 2013 and I have been banging my head on the keyboard trying to figure this out. I have a shapefile with an attribute called "MUSYM" which corresponds to a soil type. In short I need to color the polygons in the shapefile based on the "MUSYM". You can do this in GIS using categorized styling and a color ramp. I realize I can use thematic rules in the style editor (i.e. "MUSYM" = 35 ----> Orange) but I will have to do this for every MUSYM value which will be painful to say the least. Is there an *elegant* workaround for this or will using thematic rules be the easiest way? That being said I would really like to see categorized/graduated styling implemented in the FDO. It would make it a much more powerful tool.
    2012-07
    3
    Default Re: Styling Based on Attribute Values
    So I figured it out. If anyone is interested you use the FDO style editor and click on "New Theme" This allows you to specify a range of values for a given attribute to which you can assign a either a built in color theme, or a color ramp. Actually pretty easy once you know what to do!
  1. Select blocks based on attribute values...
    By tdickie651973 in forum AutoLISP
    Last Post: 2014-10-31, 02:22 PM
  2. How to change dynamic block attribute default values based on block selected?
    By zeirz109180 in forum Dynamic Blocks - Technical
    Last Post: 2013-12-13, 02:20 PM
  3. Replies: 13
    Last Post: 2012-09-18, 07:51 PM
  4. Replies: 4
    Last Post: 2008-11-13, 05:36 AM
  5. Add Attribute values together
    By ReachAndre in forum AutoLISP
    Last Post: 2007-10-31, 03:09 PM
