Thread: I am trying to make a complex label and need help with the SQL statement
    2004-11
    6
    Default I am trying to make a complex label and need help with the SQL statement
    I would like to make a label that stacks up to 4 values for a feature. I am making the label using Topobase 2010 Admin tool. In the SQL statement below my goal is to get two values from table EL_Fuse and two values from Table EL_SWITCH when the records match my features FID to their attribute FID_Structure.
    I am not trained in SQL writing but have come close with the following:
    select concat_list(CURSOR(
    select b.GC_DEVICEN||'\n'
    ||c.GC_DEVICEN||'\n'
    from EL_SWITCHGEAR a, EL_FUSE b, EL_SWITCH c
    where a.FID = b.FID_STRUCTURE
    and b.FID_STRUCTURE = c.FID_STRUCTURE
    and a.FID = $id
    ))myCursor from dual
    This results in:
    MA229\nMA227\nMA228\nMA227\nMA229\nMA226\nMA228\nMA226\n
    1 rows selected.
    What I want is:
    MA226
    MA227
    MA228
    MA229
    MA226 and ma227 come from table EL_Switch and MA228 and MA229 Come from table EL_Fuse.
    Any SQL experts out there that can correct my SQL so I get the results I want???
    2004-11
    6
    Default Re: I am trying to make a complex label and need help with the SQL statement
    I kept hacking on this and came up with a solution:
    and a.FID = $id
    union
    select c.GC_DEVICEN||'\n'
    from EL_SWITCHGEAR a, EL_switch c
    where a.FID = c.FID_STRUCTURE
    and a.FID = $id
    which returns these results:
    MA227\nMA226\nMA229\nMA228\n
    1 rows selected.
    Then when you style the label make sure the text type is text not Mtext. Only regular text recognizes the \n for next line.
    2004-11
    6
    After working with a real programmer we altered the code to the following:
    SELECT REPLACE(WM_CONCAT(GC_DEVICEN||GC_DEVICE_TYPE ||'\n'),',',null) FROM
    (SELECT FID_STRUCTURE, GC_DEVICEN, GC_DEVICE_TYPE FROM EL_FUSE
    UNION
    SELECT FID_STRUCTURE, GC_DEVICEN, GC_DEVICE_TYPE FROM EL_SWITCH)
    GROUP BY FID_STRUCTURE
    HAVING FID_STRUCTURE = $id
    Because we are using a an older version of Oracle we had to use WM_CONCAT instead of LISTAGG. If you can use LISTAGG you do not need the REMOVE statement to get rid of the commas.
  1. 2013: Can I make text style height control label text heights?
    By caddjockey2000 in forum AutoCAD Civil 3D - General
    Last Post: 2013-12-05, 04:25 PM
  2. How to make station label inserstion point at tic crosshairs?
    By adeppisch in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-11-13, 09:08 PM
  3. Replies: 0
    Last Post: 2010-10-06, 02:06 AM
  4. Complex wall make up
    By kmatis in forum Revit Architecture - General
    Last Post: 2009-11-03, 03:52 AM
  5. Replies: 9
    Last Post: 2007-03-29, 12:35 PM
Tags for this Thread
