Thread: Be able to dimension e.g. the maximum/minimum distance between the edges of two circles.
    Wish List Administration
    2011-08
    4,581
    Default Be able to dimension e.g. the maximum/minimum distance between the edges of two circles.
    Summary: Be able to dimension e.g. the maximum/minimum distance between the edges of two circles instead of only being able to dimension them between their center-points. The same problem occures when i want to measure e.g. the clearance between an arced surface and another surface, the i want the minimum distance and not the distance to the end-points or the center-point.
    Description: See above.
    Product and Feature: Inventor - Sketching
    Submitted By: Stefan Rydh on 07/31/2012
    2011-08
    4,581
    Exclamation Re: Be able to dimension e.g. the maximum/minimum distance between the edges of two circles.
    The wish has already been granted. This thread is closed to further posts.
  1. CM333-1: Maximum Training: Minimum Effort
    By Autodesk University in forum CAD Management and IT
    Last Post: 2015-08-07, 04:06 PM
  2. CP33-1: Rapid Customizing Minimum Pain, Maximum Gain
    Last Post: 2013-04-17, 04:42 AM
  3. Replies: 2
    Last Post: 2012-08-04, 05:57 AM
  4. 2011: Multiple stretch distances need minimum/maximum dimensions
    By RapidCAD in forum Dynamic Blocks - Technical
    Last Post: 2012-06-08, 07:09 PM
  5. Maximum & Minimum constraints
    By Shaun v Rooyen in forum Revit Architecture - Families
    Last Post: 2005-09-22, 09:05 AM
