Thread: Creating sheet sets from existing drawings
    2004-07
    Baton Rouge, Louisiana
    254
    Default Creating sheet sets from existing drawings
    being new to sheet sets even thou its been arouind for several years now, i've run into a problem. When creating a sheet set from existing drawings i have noticed that not all drawings are being read from the drawing directories of each job. example: i go to a job after starting the sheet set manager, i know there are 15 sheets in the job, the manager only picks up 8 sheets, i have to go back and manually insert 7 more sheets into the set. Is there a setting i am not doing, i'm following the screen prompts.
    2001-12
    St. Louis
    5,408
    Default Re: Creating sheet sets from existing drawings
    What release of AutoCAD are you using?
    I've only had that happen when my drawings didn't have formatted layouts in them (many of our campus's drawings were originally done in R10 and R12), but, it does not sound as if that is the case for you.
    Hmm, if you deleted the sheet set, and tried recreating it again automatically, are the same drawings left out?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2004-07
    254
    i did notice that when i go to add the sheets manually, i get message basicly saying that some sheets may have been used in a previously in another set. seeing how i am the only working on these jobs i do not see how this is possible.
  1. Replies: 1
    Last Post: 2013-01-18, 04:41 PM
  2. Replies: 0
    Last Post: 2012-01-25, 04:11 PM
  3. Replies: 5
    Last Post: 2011-02-12, 03:01 PM
  4. Taking Sheet Sets out of the "Recent Drawings" list
    By pmg456037 in forum AutoCAD Civil 3D - General
    Last Post: 2010-06-29, 03:51 AM
  5. new sheet set with existing drawings custom fields
    By jkipfer in forum AutoCAD Sheet Set Manager
    Last Post: 2005-02-22, 04:57 PM
