Thread: Spectral Analysis / Different Load Cases Participating to "Load Mass Conversion"
    2012-07
    Lyon - France
    3
    Default Spectral Analysis / Different Load Cases Participating to "Load Mass Conversion"
    In spectral analysis and at the "Load to Mass Conversion" we could select the Load Cases that we want to participate into mass conversion. This will follow all spectral Analysis Types.
    Is it possible to introduce different Load Cases into mass participation into 2 different spectral Analysis Types?
    Thanks
    2010-04
    46
    Default Re: Spectral Analysis / Different Load Cases Participating to "Load Mass Conversion"
    Mass type and load to mass conversion is assigned not to spectral load cases but to modal load cases preceding them. Spectral cases inherit it from preceding modal case
    You can control for which cases conversion should be active by specifying whether the converted mass is:
    1/ global - active for any load cases including static ones (like centrifugal or other inertia loads)
    2/ dynamic - active for all dynamic cases
    3/ active for selected case - if some modal load case is specified there the setting is active also for all spectral cases defined after it until another modal case
    This setting is shown on the attached screen capture.
    Regards,
    Pawel Pulak
    Support Specialist
    Autodesk, Inc.
  1. Panel schedule problem. "Load name" not changing. Urgent!
    By mit81 in forum Revit MEP - General
    Last Post: 2012-11-19, 02:22 PM
  2. 2012: "load into project" after creating custom title block
    By tterbb819318 in forum Revit Architecture - General
    Last Post: 2011-09-30, 11:25 AM
  3. 2009 Cvl 3D, ??? Load "STP" or "SHX" Files
    By d.lair.doubler in forum AutoCAD Civil 3D - General
    Last Post: 2010-09-10, 08:48 PM
  4. Verification fails: "linear load has not been applied to a panel"
    By smm.144 in forum Robot Structural Analysis
    Last Post: 2010-06-08, 08:14 AM
  5. Replies: 3
    Last Post: 2007-10-30, 07:29 PM
