Thread: can i make a contour label that leaves out a single contour?
    2009-05
    109
    Default can i make a contour label that leaves out a single contour?
    We have our surface/contours/contour labels set up already(its a beach). We have custom contour lines to represent low water, high water etc as well as a label style that labels them appropriately. However 1 of them falls basically on the 10' contour in part of the survey, so the 10' label and the high water label get in each others way. can i somehow make a contour label that skips the 10' contour?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,679
    Default Re: can i make a contour label that leaves out a single contour?
    I would adjust the Surface Label Group to not cross the 10' contour. Then have a single Surface Label to show the high water label.
    Active Member Novarese's Avatar
    2012-05
    93
    Quote Originally Posted by JRBOURNE View Post
    Try to add the 10' contour to the surface definition as a breakline, sir.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Assuming your water level contours are minor contours, set the major contour style to <none>. You can do this in the properties of an existing label group or while creating the labels.
    Jeff Paulsen
  1. Contour Label Orientation
    By cek in forum Revit - Platform
    Last Post: 2014-11-17, 09:09 PM
  2. Contour Label Precision?
    By DBUZZ in forum AutoCAD Civil 3D - General
    Last Post: 2008-11-11, 06:57 PM
  3. contour label
    By apocono74 in forum Revit Architecture - Families
    Last Post: 2008-02-19, 05:56 PM
  4. -0 contour label
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2006-07-04, 11:59 PM
  5. Label contour & Subregion
    Last Post: 2004-11-03, 10:43 PM
