Results 1 to 7 of 7
Thread: DINAMIC BLOCK
    2012-07
    56
    Lightbulb DINAMIC BLOCK
    Hey, guys..
    I have one dinamic block with 5 differents cales. But need more 11 dinamics block like that, because for each block represent one month.
    So Is there any easier way to create this blocks?
    e.g 1 block represent january - 1:2000, 1:1000, 1:500, 1:200, 1:100
    1 block february -11:2000, 1:1000, 1:500, 1:200, 1:100
    Thanks.
    attached file.
    NM-JAN.dwg
    2012-07
    56
    Default Re: DINAMIC BLOCK
    Is it possible put the month and years as a attribute of the block??
    thanks in advance
    Fabricio
    Active Member nod684's Avatar
    2016-02
    Singapore
    70
    Quote Originally Posted by fabricio_camargo84151122 View Post
    Hey, guys..
    Thanks.
    attached file.
    NM-JAN.dwg
    You dont need to create 12 blocks for each month, you just need to use Look Up Parameter for the Scale and Visibility Parameter for the Months
    please see attached file
    "Memories fade but the scars still linger..."
    2012-08
    111
    Thanks nod,
    Perfect!!
    Regards.
    2012-08
    111
    Hey all,
    I'm trying to make a dinamic block that align with a polilyne by the insert point.
    But I still didn't have sucess.
    Can someone help, please?
    Attached File.
    HELP.dwg
    Thanks in adance
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    See your other post in the Technical Section
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
    2016-02
    Singapore
    70
    Quote Originally Posted by BILLYJOW View Post
    Thanks nod,
    Perfect!!
    Regards.
    you're welcome
  1. Dinamic Block
    By BILLYJOW in forum Dynamic Blocks - Technical
    Last Post: 2013-01-30, 04:04 PM
  2. Help - Dinamic block
    Last Post: 2013-01-22, 12:06 PM
  3. Visibility States - Dinamic Block
    Last Post: 2012-11-30, 04:13 PM
  4. HELP - DINAMIC BLOCKS
    Last Post: 2012-08-24, 04:59 PM
  5. Highlight Last Opened Block in Block Editor Block List
    Last Post: 2008-10-11, 09:03 PM
