I'm trying to create a railing that looks like this:
I've always found railings that use panels quite cumbersome. I want the handrail to be continuous as well as the L-channel at the base. The balusters are held in from the end and corners and the last panel is smaller than the rest. I'd like the smaller end panel to be constant, but the central panels have to change width depending on the condition so that they are equal.
Since I want the railing to turn the corner, I'd like it to be one railing. However, the size of the central panels from the front to the side will not be the same.
Any thoughts? (The image you see is a generic model family where I just built up the geometry for the whole balcony. I'd prefer to make the balcony a link so I can have real floors, walls, and railings.)
