Thread: Help! Door swing won't show up in plan
    2004-08
    183
    Default Help! Door swing won't show up in plan
    So here's the situation. I have a custom built door family that works perfectly in a test model. It even in works in one level with my main project. But for some reason the door swing (which is a nested door swing family) does not show up in my first floor plan.
    The visibility settings for the swing family are set to Plan/RCP, coarse, medium, fine. The swing is made up with standard sub category lines (panel cut, swing) and these are untouched in the object styles.
    The phasing is set to show complete and the doors are definitely in new construction.
    What am I missing?
    The crazy thing is if I copy the door from the corrupt project into a brand new test project (where the doors work fine), the copied door still doesn't show up. But if I insert a fresh copy of the door into the test project then it works fine. I'm afraid that my entire project might be corrupt and there is nothing I can do to fix this. I can't even copy the objects into a new file because they still won't show up!!!!
    Please Help!
    2004-08
    183
    Default Re: Help! Door swing won't show up in plan
    Stupid. The door swing family is set at the bottom of the door and my floor was covering it up. I just raised the swing up in the Z direction and all is good. Stupid, stupid!
    AUGI Addict jsteinhauer's Avatar
    2015-11
    Madison, WI
    1,317
    Noah,
    Its a learning experience...don't take it to hard on yourself. Did you create your swing lines as model lines or detail lines? From the sounds of it, you made them as model. Not a 100% sure, but that might have solved it too, w/o raising the nested family in the Z direction.
    Cheers,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    You might consider using symbolic lines for the swing and door panel in plan views, and set their visibility in the Family. The OOTB Door Family is set up this way for comparison.
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2009-12
    Albuquerque, NM
    167
    Don't be hard on yourself. We had exactly the same problem and it was a real stumper before we figured it out. The real trick are those 1/8" architectural floor finishes above the slab. I seem to recall that the only way we even figured it out was in looking at a janitor's closet that was intended for sealed concrete.
    -LP
  1. Why does door swing show in RCP?
    By brent.130528 in forum Revit Architecture - General
    Last Post: 2019-05-11, 07:38 PM
  2. Floor Finish Obscures Door Swing in Plan View
    By ddragoo144336 in forum Revit Architecture - Families
    Last Post: 2008-11-06, 11:31 PM
  3. Door family w/ curved swing new and straight swing existing
    By ericsson in forum Revit Architecture - General
    Last Post: 2007-12-19, 04:02 PM
  4. Door Swing Plan
    By wse1 in forum Revit Architecture - Families
    Last Post: 2007-02-13, 10:55 PM
  5. Attaching a door plan swing to the door leaf?
    By patricks in forum Revit Architecture - Families
    Last Post: 2005-03-24, 07:56 PM
