Thread: Negative pressure values
    2011-08
    Vila Nova de Gaia
    2
    Default Negative pressure values
    I have been facing some difficulties in REVIT MEP 2013, due to an unstable calculation in pressure values.
    Everything works mostly well, unless i use fittings, there's where the problem begins. At first i couldn't even select a table from the ASHRAE catalog, when i figured that out, i got another issue, my Pressure Loss is negative with a elbow in it.
    But when i go to the elbow and force it to a specific pressure loss, the system works. This could be the solution, but since i can't choose Tee's to have specific pressure loss, it messes with my design. Any ideas about this negative value in the system?
    2011-08
    Vila Nova de Gaia
    2
    Default Re: Negative pressure values
    No one? Not even a hint?
  1. Negative parameter values
    Last Post: 2013-12-12, 12:55 PM
  2. Negative Soil Pressure and Uplift
    By derek.plehal in forum Robot Structural Analysis
    Last Post: 2010-10-15, 10:31 PM
  3. How to quick select postive or negative text values
    By Jawwad Malik in forum AutoCAD General
    Last Post: 2010-05-25, 12:08 PM
  4. Replies: 6
    Last Post: 2009-08-20, 03:16 PM
  5. parameter won't allow negative values
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2009-04-14, 01:31 PM
