hi, how can we make a spring visually moved? can anybody explain the issue step by step please. thanks in advance
Attach the two parts here that will be in mated to the spring.
There are at least 3 methods.
I would use a parameter for height of spring and animate parameter in Inventor Studio.
Easiest method might be to add Spring Force in Dynamic Simulation, but that requires knowledge of Dynamic Simulation Environment.
Third technique would be adaptive components technique. You should probably stick with the first method to start.
I found a good tutorial for an adaptive spring here: http://designandmotion.net/autodesk/...y-and-springs/
Rob.
