Thread: Can I UNfade locked layers?
    2004-02
    109
    Default Can I UNfade locked layers?
    Hello,
    In DWG TrueView locked layers are set to display at 50%.
    In AutoCAD this setting is controled by variable LAYLOCKFADECTL.
    Is there any way to modify the equivilent of this variable in TrueView?
    My users would like to see all layers at full visibility and not have the locked layers faded.
    Thank you,
    Steve
    Earth
    9,804
    Default Re: Can I UNfade locked layers?
    You can edit this in the registry.
    Make sure DWG Trueview is not open
    Go to:
    HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R10\dwgviewr-Bxxx:xxx\Profiles\<<Unnamed Profile>>\Drawing Window
    Create a DWORD (32bit) value named "LayLockFadeCtl" and set the value to 0.
    Launch DWG Trueview and test.
    R.K. McSwain | CAD Panacea |
  1. Ignoring Locked Layers
    Last Post: 2013-11-20, 02:02 PM
  2. Locked Layers
    By Aquaserpent in forum AutoCAD Civil 3D - General
    Last Post: 2011-09-23, 05:25 PM
  3. Unscreening Xref on Locked layers
    By aport in forum AutoCAD LT - General
    Last Post: 2011-03-01, 07:18 PM
  4. Fade XREFS on Locked Layers
    Last Post: 2009-07-05, 05:39 PM
  5. Fading Locked Layers
    By Firmso in forum AutoCAD General
    Last Post: 2008-07-07, 11:27 PM
