Results 1 to 9 of 9
Thread: Newbie question: How do I get a command in LISP to stay "open" or "active"?
    All AUGI, all the time gfreddog's Avatar
    2003-07
    Pequannock NJ US of A
    641
    Default Newbie question: How do I get a command in LISP to stay "open" or "active"?
    Ok... so I have a LISP that I want to run and sets Rev Cloud to the setting I want then you can select the polyline object you want to turn into a Rev Cloud:
    ;RVCLD- Rev Cloud set to object
    (vl-load-com)
    (DEFUN C:RVCLDs()
    (COMMAND "LAYER" "SET" "1G_Rev Cloud" "")
    (command "_revcloud" "a" "3/16" "3/16" "s" "c" "o" txt)
    So what this does is:
    Command: RVCLDSCurrent layer: "1G_Rev Cloud"
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: SET
    Enter layer name to make current or <select object>: 1G_Rev Cloud Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:
    Command: _revcloud
    Minimum arc length: 3/16" Maximum arc length: 3/16" Style: Calligraphy
    Specify start point or [Arc length/Object/Style] <Object>: a
    Specify minimum length of arc <3/16">: 3/16
    Specify maximum length of arc <3/16">: 3/16
    Specify start point or [Arc length/Object/Style] <Object>: s
    Select arc style [Normal/Calligraphy] <Calligraphy>:c Calligraphy
    Specify start point or [Arc length/Object/Style] <Object>: o
    Select object:
    Command: nil
    How do I get it to stay on "Select Object" and stop closing?
    Thanks
    George V. Fournier Jr., CTS
    Sr. Sales Engineer - Autodesk Product Design Suite Premium 2014
    2006 AUGI DAWG (7th) - NJ AUGI Camp
    Volunteer Firefighter since 1985 & Bagpiper Wanna-be
    With the freedom of expression comes great responsibility
    All AUGI, all the time marko_ribar's Avatar
    2015-10
    Belgrade, Serbia, Europe
    557
    Default Re: Newbie question: How do I get a command in LISP to stay "open" or "active"?
    (DEFUN C:RVCLD nil
    (COMMAND "._LAYER" "M" "1G_Rev Cloud" "")
    (COMMAND "._REVCLOUD" "A" "3/16" "3/16" "S" "C" "O")
    (PRINC)
    M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on Youtube
    2003-07
    641
    That was it thanks!
    2009-11
    5,593
    ... Or you could use the PAUSE keyword.
    2003-07
    641
    Quote Originally Posted by RenderMan View Post
    huh? how does that go? Pls forgive the newness I'm learning LISP bit by bit
    2009-11
    5,593
    Quote Originally Posted by gfreddog View Post
    While not necessary in this circumstance, as Marko's suggestion is more succinct, in many instances the PAUSE keyword can be very useful. Here's an applicable example, that is functionally the same as Marko has posted above:
    (COMMAND "._REVCLOUD" "A" "3/16" "3/16" "S" "C" "O" PAUSE)
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2003-07
    641
    Ah now that makes sense. Thanks for the info
    Active Member JohnCAVogt's Avatar
    2001-03
    St. Louis
    75
    really elegant that would make the pause usefully necessary would be:
    (DEFUN C:RVCLD ( / strCurrentLayer)
    (setq strCurrentLayer (getvar "clayer"))
    pause
    "._layer" "m" strCurrentLayer ""
    (PRINC)
    2009-11
    5,593
    You're welcome.
    FWIW -
    You may, or may not already use Command Reactor(s) in your setup, but this is a great illustration of where employing one is useful... That way, you also avoid having to account for the *error* thrown when trying to modify the CLAYER System Variable while the REVLCOUD Command is still 'active'.
    Computer Specs:
  1. Replies: 0
    Last Post: 2013-12-13, 04:06 PM
  2. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  3. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
    Last Post: 2009-02-01, 04:21 AM
  4. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
  5. Replies: 3
    Last Post: 2006-03-23, 10:25 PM
