1. Here's a file:
LASANTHA.dwg
When you open it, you'll see how I've set up my viewports. You can see the hidden lines of the hollow chamber inside the fireplace. If you then select those red/hidden lines, you'll see that they are drawn in on paperspace. I drew those because I couldn't figure out how to get Autocad to display the hidden lines. I can save a lot of time in the future if I can do this a faster/easier way, rather than tracing overtop of the object with hidden lines manually. It's a pretty straightforward question: How do I get autocad to automagically display hidden lines like the ones in my example fireplace?
Second question:
2. Perspective view in 3D drives me nuts. I always find myself having to switch back to Parallel view. In case you can't see the difference, try changing it yourself. Some people find this to be a minor different but it makes a big impact in the way that I draft in 3D.
Here's the question, is there any way I can get Autocad to remember that I like Parallel view and NOT perspective view?
Thanks in advance
-Anton
