Thread: how to tie visibility parameter to attribute?
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    632
    Default how to tie visibility parameter to attribute?
    in the process of combining multiple blocks to a single dynamic block w/ attributes, just wonder if there's a way to tie that visibility parameter value to attribute value?
    for instance, in the drawing, i have 2 instances of that dynamic blocks, one's visibility parameter is set to "A", and another is "B", can attribute value be automatically set to "A" or "B"?
    thanks.
    2010-06
    57
    Default Re: how to tie visibility parameter to attribute?
    I think this is what you are trying to achieve.
    Go into block editor choose the visability state you want to link to the attribute & create a new atrribute.
    For the default value click on the icon next to the default box this should give you a list of the fields.
    Field catagory = Blockplaceholder
    block ref prop = visability
    Choose your upper or lower case.
    Save & exit block editor & then run the command attsync & hopefully you should get what you need.
    I managed to get this to work but after a lot of help from the contributers to these forums
    2006-08
    632
    thanks lesleys, that's exactly what i'm looking for, at first i thought it cannot be done except good old programming tricks like lisp, etc.
    well, stayed away from AutoCAD for very long time, a bit rusty but good to know that DB can achieve similar result like Revit's family.
    2006-08
    632
    look like i have trouble to embed it into macro like lisp, i specified attribute value in macro but it always uses default value instead, any idea?
    edit: even if i manually insert that block, still used default attribute value instead of specified one.
    edit: uploaded DWG.
    2015-09
    4
    I was made short video for solve this problem , please visit here.
    2016-03
    No Link. Could you repost it please?
  1. Replies: 8
    Last Post: 2013-09-26, 07:37 PM
  2. Yes/No Visibility Parameter with Secondary Parameter Help
    By bpayne in forum Revit Architecture - General
    Last Post: 2011-06-15, 05:52 PM
  3. DB attribute visibility not working.
    By M. Kubitza in forum Dynamic Blocks - Technical
    Last Post: 2009-08-20, 02:56 PM
  4. Dyamic Blocks & Attribute Visibility
    By smp in forum Dynamic Blocks - Technical
    Last Post: 2009-03-17, 06:34 AM
  5. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
