Hello - did a search but didnt see this - sorry if its been covered.
I am having a problem with the stock cast iron hub and spigot fittings in MEP2013. It seems that all the fittings have their connectors set out a 1/4" longer than the true end to center dimension.
For example a 3" - 1/4 bend has a end to center dimension of 4" from center line to makeup on the hub(the data in the catalog editor shows this to be correct). However when I place a fitting and measure from center to the "fitting snap" connector the dimensions is 4 1/4".
Again the data in the catalog is correctly showing 4" but the snaps are placed a 1/4 further out.
Hopefully its something obvious I am missing. Any help is appreciated.
