Thread: How to build this bubble in a famliy?
    2007-09
    83
    Default How to build this bubble in a famliy?
    and then fill it in a curtain wall?
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: How to build this bubble in a famliy?
    A revolve mass with a divided surface. You won't use a curtain wall but a curtain system with pattern based adaptive curtain panels.
    2006-09
    259
    If I were you I would try this in Rhino+Grasshopper and then use one of the tools available out there to link grasshopper point data to place adaptive components in Revit.
    *Edit: Just saw Dmitri's reply after posting mine. Revolve could work but it will add seam line whereas proposed bubble has seamless grid for panelization.
    2007-09
    83
    Red face Re: How to build this bubble in a famliy?
    at last I make it out
    here is the result, both works well, thanks for the help
    almost take me one year
    2008-09
    Nebraska & Iowa
    378
    Nice work!
  1. Call out Bubble
    By mjohns18 in forum Revit Architecture - General
    Last Post: 2010-03-10, 01:13 PM
  2. Debug Build v's Final Build
    By Phillip_Miller in forum Revit - API
    Last Post: 2009-03-15, 01:40 AM
  3. Drafting view of a famliy that's not included in a schedule
    By Dave F. in forum Revit Architecture - General
    Last Post: 2008-12-17, 05:37 PM
  4. New Build Comments (moved from new build announcement)
    By sfaust in forum Revit Architecture - General
    Last Post: 2007-10-15, 08:38 PM
  5. 2008 CD build vs. download build - the same?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2007-04-19, 08:51 PM
