I'm trying to dimension the angles around a circle. I'm running into 2 problems. 1) if the angle is 180 degrees, it considers the angle to be on a single line and won't create the dimension and 2) if the angle is greater than about 144 degrees it rotates the whole dimension off of the base point and creates an angle dimension of 144 degrees. Am I missing something or is there a work around?
I've attached a file.
