Thread: 32bit MS Access import Data to 64bit Win 7 system for Revit 2009 & 2013
    2016-02
    Sydney, Australia
    512
    Default 32bit MS Access import Data to 64bit Win 7 system for Revit 2009 & 2013
    Hi,
    I'm no expert in this area, and seek your advice. I have a database on 32bit MS Access, and I wish to extract some data to autofill parameters in the titleblock, and a schedule in a Revit file. I understand that there are some issues in regard to installation of the add on software for database use, which appears to be resolved on this thread. http://forums.augi.com/showthread.ph...e+import+revit Also it puzzles me why this isn't part of the inital install. I am currently using Revit 2009 32bit on a 64 bit machine, but will be upgrading soon to 2013 64bit, and wonder if I should save myself a heap of agro & hold off on the process if the 2013 version does it better.
    Anyway I could see no tutorials or tips on this subject, and wondered if you had any advice?
    2006-05
    Seattle, WA
    180
    Default Re: 32bit MS Access import Data to 64bit Win 7 system for Revit 2009 & 2013
    Quote Originally Posted by Norton_cad View Post
    Hi,
    If you upgrade to Revit 2013 64-bit, you will need to use Access 64-bit or Excel in order to exchange data.
    2016-01
    Albuquerque New Mexico
    53
    I've gone through this and if your Revit no mater what version is 64 bit your ms office needs to be 64 bit as well or else the links will be broken and you will not be able to export your revit database.
  1. Replies: 2
    Last Post: 2010-11-21, 09:44 PM
  2. Using DVB's for 32bit and 64bit Windows 7
    By ccaron in forum VBA/COM Interop
    Last Post: 2010-02-12, 11:08 PM
  3. 32bit vs. 64bit
    By fwp in forum Revit - API
    Last Post: 2009-12-19, 07:08 PM
  4. Revit 32bit vs. 64bit
    By tknapp in forum Revit - Hardware & Operating Systems
    Last Post: 2009-11-16, 09:05 PM
  5. Install 32bit and 64bit together?
    By Andre Baros in forum 3ds Max - General
    Last Post: 2008-11-04, 02:15 PM
