Hi! I am new in the forum, I hope here i can find the answer to my civil 3d points issue!!
I've been trying to create a surface with Civil 3d from a topo file that i received. The thing is that in this file, the points are shown as blocks. They look like this:
....9723
X .14.678
....EOP
(Point number, elevation and code). All these blocks are all at elevation 0. If i explode them i have 3 mtexts and 2 lines.
How can i do to create civil 3d points from these blocks maintaining at least the elevation and position and if possible the code?? (so maybe later i can easily create the surface with the corresponding breaklines).
I've tried to explode the blocks and then using command movetexttoelevation but i lose lot of information doing this, and also i need to delete many mtexts that are not elevations and move the texts to the cross...
Also i found some lisps but they didn't work on my case. This may be because i think the blocks lost their original name.
Does anyone know how to work with these points??
Thanks!
