Thread: Revit Mystery: Case of Unexpected Results
    2015-09
    Edmonton, AB, Canada
    29
    Default Revit Mystery: Case of Unexpected Results
    I have some valve families which we use extensivly on our projects. Some of these valves can be changed from one size to another without problem. Others give the error message: "Changing the family for a MEP fitting might cause unexpected results."
    Why would one work and the other not? Please see a 2 minute video at: http://www.screenr.com/Nv68 which further illistrates the problem.
    2005-12
    53
    Default Re: Revit Mystery: Case of Unexpected Results
    Have you tried clicking on the Expand>> in the window that displays the message: "Changing the family for a MEP fitting might cause unexpected results."
    I suspect it is referring to the fittings the valve is connecting to... not the valve itself.
    2011-11
    I'm having this same error. Does anyone know of a fix? Clicking expand in the window is not helpful like most Revit errors.
    2015-09
    29
    This mystery was solved for us. For our valve families, with two connectors, the solution was to re-assign which connector was primary.
    Hope this works for you as well!
  1. 2012: Revit Mystery: Case of the Non-Appearing Room Names
    By tuitvlugt in forum Revit MEP - General
    Last Post: 2012-06-11, 08:18 PM
  2. Changing the family for a MEP fitting might cause unexpected results.
    By bejenaru.a in forum Revit MEP - Families
    Last Post: 2012-04-25, 09:10 AM
  3. Help: Stretch @ Rotation: Unexpected Results
    By chillme1 in forum Dynamic Blocks - Technical
    Last Post: 2009-01-07, 12:40 PM
  4. Removing Dim. Points Produce Unexpected Results
    By cjthompson85424 in forum ACA General
    Last Post: 2005-06-14, 02:15 PM
Tags for this Thread
