Thread: Import Nodes from Spreadsheet
    2010-10
    21
    Default Import Nodes from Spreadsheet
    Hello Everyone i hope you can help.
    I was wondering is it possible (and if so how) to import nodes from a spreadsheet?
    I have a spreadsheet with all the node coordinates and was hoping to use this to construct a steel frame.
    Any help would be most gratefully recieved!
    thanks
    ANdy
    2010-04
    46
    Default Re: Import Nodes from Spreadsheet
    The simplest way is to use Copy&Paste on Edit tab of the table of nodes. As in this video: http://screencast.com/t/kfqh59S4s
    Regards,
    Pawel Pulak
    Support Specialist
    Autodesk, Inc.
  1. How to import text from a Excel spreadsheet to Acad (using ObjectDbx)
    By Michel.Levesque.ST522691 in forum VBA/COM Interop
    Last Post: 2014-03-20, 09:19 PM
  2. Polyline with too many nodes!!!
    By JohnnyCicc in forum AutoCAD General
    Last Post: 2012-07-07, 07:57 PM
  3. 2012: Analytical Nodes
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2011-10-25, 07:35 PM
  4. Nodes to Points
    By scott.epp in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2011-04-08, 08:12 PM
  5. import/export layers into spreadsheet
    Last Post: 2006-01-12, 04:11 PM
