Hi everybody, I am trying to access AutoCAD from a Visual Basic Windows form, and pulling my hair out. Every bit of help I can find from Autodesk involves .NET class library projects, the available wizards are for same, and the only internet references I can find to do what I want say something like "you cant reference the .NET dlls if using a Windows form, you can only use the .COM references, Autocad libraries and ObjectDBX". OK, so I have tryed a hundred ways of doing that without success. I used to use userforms in VBA and migrated to VB6 and was still able to access AutoCAD from forms and this is the way I would prefer to continue with Visual Studio (I would also prefer to keep using "Thisdrawing" , but it seems impossible no matter how many web contributers say otherwise). Is there anyone out there that has accomplished what I am trying to do, or is this way of programming very unfortunately going completely extinct and Netload is the only option left? (currently working with trial versions of AutoCAD 2013 and Visual Studio 2010 at home but at work I use AutoCAD 2011 which is what I really need to update my old projects for)
Thanks for any help...
