Hi AUGI Members,
We are using AutoCAD Architecture 2013 on 64bit Windows 7 workstations. All of our workstations are setup exactly the same however, on one computer, we are experiencing a strange font problem.
When using the following command (Command "-STYLE" "Dtest" "Arial.ttf" "1.00" "1" "0" "N" "N") the command fails with the message "Font file doesn't exist". This only occurrs on this one workstation, all of the other stations work fine and their AutoCAD environment is setup exactly the same. The Arial true type font is installed on all workstations so I do not think that is the problem. If I copy/clip a block file that has the Arial.ttf font in it......then the above command will work OK.
Has anyone come accross this type of problem....?? or have some recommendations or suggestions on how to resolve this issue....??
Your feedback will be appreciated....!
Regards,
Vince
