Results 1 to 10 of 12
Thread: unknown command
    2010-02
    7
    Default unknown command
    Why is autocad saying -blockreplace is and unknow command??
    (DEFUN C2e (/)
    (setvar "cmdecho" 1)
    (command "-BLOCKREPLACE" "cd-relay" "cde-relay" "y")
    (PRIN1))
    Command: P2e
    -BLOCKREPLACE Unknown command "-BLOCKREPLACE". Press F1 for help.
    Command: cd-relay Unknown command "CD-RELAY". Press F1 for help.
    Command: cde-relay Unknown command "CDE-RELAY". Press F1 for help.
    Command: y Unknown command "Y". Press F1 for help.
    Command:
    5,714
    Default Re: unknown command
    Welcome to AUGI!
    BlockReplace is an Express Tools Command... If you're getting an unknown command error, simply add the ..\Express\ folder (in your installation path) to your Support Files Search Path (SFSP), and ensure that the AcetMain.Cuix is loaded as Partial CUIx.
    HTH
    2010-02
    7
    The Express folder path is in my support files search path and the acetmain.cuix is loaded. The command (-blockreplace) works if I type it in at the command prompt, just not as a lisp!!
    2010-06
    962
    Quote Originally Posted by traci.242201 View Post
    If you want to call an Express tools' command calls directly from a lisp routine , you should call it like this (c:ReplaceBlock) and I am not sure if you can feed it the same way you are doing .
    5,714
    More on the c:-BlockReplace LispFunction:
    (startapp "explorer" (findfile "blocktoxref.lsp"))
    2004-08
    Iron Station, NC
    3,198
    I dont believe you can enter the prompts for the block replace command. it has something to do with the fact that it doesnt accept arguments, only answers to prompts. If you want to do it that way, you need to hardcode your answers into a copy of the original express tools lsp file, assuming its a lsp, not an arx. I have done it in the past for enclose text in object routine. alternatively you could also set up the program so it takes arguments, but that is a little more involved.
    2010-02
    7
    Thanks for the info. I have tried all the above ideas but with no success. Thanks for the input.
    Tallahassee, FL USA
    3,658
    Try searching the AutoLISP forum for "BLOCKREPLACE", I found a few threads that may answer your questions. If you post what code you have so far and a good description of what you want the code to do you will generally get the help you need here. Adding what you do and what version and type of AutoCAD software you're using to your signature helps folk know what you need as well.
    2000-09
    Honolulu HI
    1,106
    You can create a script file
    (since you cannot run the express tools function by re-entering lisp from lisp)
    Call it blockreplace.scr
    (c:-blockreplace)
    CD-RELAY
    CDE-RELAY
    Y
    Then you can call that script from lisp
    (command "script" "blockreplace.scr")
    And replace the blocks.
    P-
    AutomateCAD
    5,714
    Quote Originally Posted by peter View Post
    (c:-blockreplace)
    CD-RELAY
    CDE-RELAY
    Y
    P-
    Neat idea Peter... Just look out for errors:
    Command: _SCRIPT
    Enter script file name "foo.scr"
    Command: (c:-blockreplace)
    Initializing...
    Select the block to be replaced or [?/= (select object)]: CD-RELAY
    The block 'CD-RELAY' was not found.
    Select the block to be replaced or [?/= (select object)]: CDE-RELAY
    The block 'CDE-RELAY' was not found.
    Select the block to be replaced or [?/= (select object)]: Y
    The block 'Y' was not found.
    Select the block to be replaced or [?/= (select object)]: *Cancel*
    Command:
    Perhaps instead, it would be prudent to have a LISP file call the script (.SCR), only _if_ the predefined blocks exist:
    (defun c:MyBlkRep ()
      (if (and (tblsearch "block" "CD-RELAY")
               (tblsearch "block" "CDE-RELAY")
        (command "._script" "<YourFilePath>\\<YourFileName>.scr")
        (prompt "\n** Block not found ** ")
    I would simply store this LISP, and the associated Script in the same location, with the same file names (obviously different extensions).
    HTH
  1. 2007: Publish Command says unknown command in autocad 2007
    By drajappa594109 in forum AutoCAD General
    Last Post: 2012-07-13, 03:34 PM
  2. AutoCAD LT 2007 Appload command returns - unknown command
    By tbedrich in forum AutoCAD LT - General
    Last Post: 2007-04-10, 02:09 PM
  3. Rectangle command returns - unknown command
    By rhayes.99001 in forum AutoCAD General
    Last Post: 2006-11-27, 02:33 PM
  4. _ai_molc command returns unknown command message
    By jan.pennabecker in forum AutoCAD Customization
    Last Post: 2006-05-19, 12:02 AM
  5. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
