This may seem long-winded but hang in there...
What?
Have set up a custom A1 Title block for our office, using the A1 title block template.
Thought I'd be clever and link the office address into the new title block template file.
Why?
Because the company is Nationwide (Australia) and I wanted to use just one title block but have the flexibility of different addresses for each state office.
How?
We already have identically named .dwg address files set up on identical paths for each server in each state (used as x-refs in Autocad drawings). Each has the office address for that particular state. Still with me?
The end result is that when each office opens a new project, their office address automatically appears in the title block.
Does it work?
Sort of.
A problem exists with the original linking process. The file links in okay to the title block template file but the links manager command is greyed out. This means I cannot check to see if the link path is relative or absolute. I have a sneaking suspicion that all links are set by default to a relative path. Herein lies the problem - our .dwg files reside in a different location (same drive), so the link can't be found.
I want to set the path as absolute but can't find a way to do so in the template file.
Any suggestions?
Comments from Factory Guys and Gals?
