Results 1 to 1 of 1
Thread: EXPORTING TO WINAIR 4 WITH LUA - NO APP. AUTO-RUN AND SET DATE!
    2012-09
    2
    Default EXPORTING TO WINAIR 4 WITH LUA - NO APP. AUTO-RUN AND SET DATE!
    Hi dear Augi user group!
    I have a small problem regarding some Lua commands in the Ecotect script tool: i would like to export my model to WinAir 4 using the scripting process, the only issue is that 2 commands in particular 90% of the times look like they are ineffective, i'm talking about the:
    1) cmd("model.export.run.air", filename.air) ...wich does not start automatically with the .run prefix the WinAir 4 application
    2) set("model.time", time) ...wich does not change the time in the model space
    I uploaded also 2 images to be more clear:
    I even saved the script on a notepad file, just copy it in the script tool.
    Thanks for your help...
    Stefano///
  1. Display Date/Time when exporting Presenter
    By reindelt585088 in forum NavisWorks - General
    Last Post: 2011-07-28, 04:07 PM
  2. Replies: 13
    Last Post: 2010-07-28, 05:14 AM
  3. Exporting errors using Auto Crete in AutoCAD 2006
    By timn.103462 in forum Software
    Last Post: 2006-01-18, 08:30 PM
Tags for this Thread
