I am looking for a Dynamic Part Callout Tag that will not break apart when streching one end or the other and the base point woun't float around but stay in one location, i.e. Arrow tip or ball center. I am also looking to be able to change the arrow to a ball as well as flip the entire tag and comments. I would also like to be able to change the "bubble" from a Hexigon to Circle to Triangle to Square. The Part number with in the "bubble" will need to recognize other callouts on the sheet and ask if it should autonumber based on the highest number there. Also would need to be able to select the preceeding letter, i.e. "R" in R3 or "E" in E5 etc. If it could reconognize the block that the arrow or Circle base p oint touches and accepts the blocks name as the Description would be great as well. It could then count the number of same blocks to auto populate the qty. Can any help me with this or find one that has already been made? My searches have come up empty. Please advise, Thank you!
